Manual focus
Magnifying the area where you want to focus when focusing manually
When you adjust the focus manually, such as when using an A-mount lens, a manual focus lens, or a lens without signal contacts, etc., you can quickly magnify the area where you want to focus by assigning the [Focus Magnifier] function to a custom key.
We recommend assigning it to an easy-to-operate button such as the AF-ON button. If you often move the magnification position away from the center, we recommend assigning the function to the center of the multi-selector or the center of the control wheel.
| Advance preparation |
| Shooting | The focus magnification scale switches every time you press the assigned key.
How to turn the peaking display on/off in the manual focus modes
You can turn the peaking display on or off quickly while shooting with [Manual Focus] or [DMF] (direct manual focus). We recommend assigning the function to an easy-to-operate button, such as the AF-ON button.
| Shooting | You can switch the peaking display on/off by pressing the assigned key. |
Magnifying the area where you want to focus right after moving the position of the focus magnifier
In the manual focus mode, you can move the magnified position using the multi-selector. When using an A-mount lens, a manual focus lens, or a lens without signal contacts, etc., you can magnify the image right after you move the position by assigning the [Focus Magnifier] function to the center button of the multi-selector.
| Shooting | Align the focusing frame for [Spot] with the area that you want to magnify using the multi-selector. Then, press the center button of the multi-selector to magnify the area.
All images and illustrations used on this page are provided for illustrative purposes only.
