Cikk azonosítója : 00197062 / Utoljára módosítva: : 12/01/2021
Sony 4K tv-készülék beállítása UHD/4K/HDCP 2.2 kompatibilis HDMI-csatlakozáshoz
    HDCP stands for High-bandwidth Digital Content Protection, a copy prevention technology used on HDMI connections.
    Version 2.2 is specifically designed to prevent illegal copying of 4K Ultra HD content.
    1. Please look at the tables below to find out which HDMI port you need to use to connect the UHD / 4K device via HDMI.
      (UHD devices such as Sony PS4 Pro, Sony UHD BD-Players, Sky Q UHD box, BT UHD box, etc.)
    2. Please enable ‘HDMI Enhanced Mode’ for the HDMI input for 2015, 2016, and 2017 models.
      To view 4K or HDR pictures at 18 Gbps:*
      • Use a Premium High Speed HDMI cable for 18 Gbps
      • Set HDMI signal format to Enhanced format
        • Press the HOME button on the remote control
        • Select Settings
        • Select External inputs in the TV category
        • Select HDMI signal format and set to Enhanced format
    *4K (50, 60 Hz) with YCbCr 4:4:4, YCbCr 4:2:2, YCbCr 4:2:0 / 10bit, RGB, HDR picture, etc.
    2018 Sony 4K TV models: All HDMI ports support 4K connected inputs/devices
    KD-65ZD9  KD-55XF8096KD-75XF9005KD-65XF8596KD-55XF8599KD-43XF8796KD-49XF7596KD-55XF096KD-49XF7004
    KD-75ZD9KD-49XF8096KD-65XF9005KD-65XF8577KD-55XF8588KD-43XF8505KD-43XF7596KD-55XF077KD-43XF7096
    KD-55AF9KD-43XF8096KD-55XF9005KD-65XF8599KD-49XF8796KD-43XF8596KD-65XF7096KD-55XF7004KD-43XF7000
    KD-65AF9KD-65AF8KD-49XF9005KD-65XF8588KD-49XF8505KD-43XF8577KD-65XF7055KD-55XF7003KD-43XF7005
     KD-55AF8KD-85XF8596KD-55XF8796KD-49XF8596KD-43XF8599KD-65XF7004KD-49XF7096KD-43XF7077
      KD-75XF8596KD-55XF8505KD-49XF8577KD-43XF8588KD-65XF7003KD-49XF7005KD-43XF7004
      KD-65XF8796KD-55XF8596KD-49XF8599KD-65XF7596KD-65XF7000KD-49XF7077
      KD-65XF8505KD-55XF8577KD-49XF8588KD-55XF7596KD-55XF7005KD-49XF7073
    2017 Sony 4K TV models: All HDMI ports support 4K connected inputs/devices
    KD-77A1KD-75XE9405KD-75XE9005KD-75XE8596KD-55XE8096KD-65XE70xxKD-43XE8396
    KD-65A1KD-65XE9305KD-65XE9005KD-65XE85xxKD-49XE80xxKD-55XE70xxKD-49XE8396
    KD-55A1KD-55XE9305KD-55XE9005KD-55XE85xxKD-43XE80xxKD-49XE70xxKD-55XE8396
      KD-49XE9005  KD-43XE70xx
    2016 Sony 4K TV models: All HDMI ports support 4K connected inputs/devices
    KD-43XD8005KD-49XD7004KD-50SD8005KD-65SD8505KD-75XD8505
    KD-43XD8077KD-49XD7005KD-55SD8505KD-65XD7504KD-75XD9405
    KD-43XD8088KD-49XD8005KD-55XD7004KD-65XD7505
    *HDMI 2 & 3 only
    KD-75ZD9
    KD-43XD8099KD-49XD8077KD-55XD7005KD-65XD8505KD-85XD8505
    KD-43XD8305KD-49XD8088KD-55XD8005KD-65XD8577KD-100ZD9
     KD-49XD8099KD-55XD8505KD-65XD8599
     KD-49XD8305KD-55XD8577KD-65XD9305
      KD-55XD8588KD-65ZD9
      KD-55XD8599
      KD-55XD9305
    2015 Sony 4K TV models: All HDMI ports support 4K connected inputs/devices
    KD-43X8305CKD-49X8005CKD-55S8005CKD-65S8005C
    KD-43X8307CKD-49X8305CKD-55S8505CKD-65S8505C
    KD-43X8308CKD-49X8307CKD-55X8005CKD-65X8500C
    KD-43X8309CKD-49X8308CKD-55X8500CKD-65X8505C
     KD-49X8309CKD-55X8505CKD-65X8507C
      KD-55X8507CKD-65X8508C
      KD-55X8508CKD-65X8509C
      KD-55X8509CKD-65X9005C
      KD-55X9005CKD-65X9305C
      KD-55X9305C KD-75X8505C
       KD-75X9105C
       KD-75X9405C
    2014 Sony 4K TV models: Please use HDMI 1 or HDMI 2 inputs
    KD-49X8505BKD-65S9005BKD-75S9005B
    KD-55X8500BKD-65X8500BKD-79X9005B
    KD-55X8505BKD-65X8505BKD-85X9505B
    KD-55X9005BKD-65X9005B
