Skip navigation
  • rich912 9,306 bejegyzés a következő időpont óta:
    Aug 28, 2004
    Létrehozás ideje Feb 13, 2012 10:36 PM
    As you have probably noticed this problem has been brought to the attention of Support on a number of occasions. Unfortunately there has been no resolution to date and it would seem that none willl be forthcoming.
    Rich
    Go n-éirí an bóthar leat
    • Válasz
  • 22 bejegyzés a következő időpont óta:
    Feb 10, 2012
    Létrehozás ideje Feb 14, 2012 3:34 AM
    I guess I am a bit lucky. This problem didn't show up on my end.
    _______________
    Business is the game!!
    • Válasz
  • 2 bejegyzés a következő időpont óta:
    Feb 2, 2011
    Létrehozás ideje Feb 18, 2012 11:31 AM
    Dear Readers,
    I have followed this thread for some time . . . . I too have suffered from this isue.
    For those that are trying to solve this isuue here is some background on a cure:
    I look after 3 Vaio VCPEC2SOE Computers (Win 7 Home Premium 62bit)
    Each was  set-up by me in the same way (two were then given to their users) I keep one.
    Each has a complete installation of Norton 360 premium (initially ver 5)
    Each has been routinely updated by windows update and by the  Vaio Inbuilt "maintenance" software.
    Only my computer had the problem!!
    This week, as you all are likely to know, there as a large windows update (Feb 2012) and Norton offered a product upgrade to Ver 6.
    The two (fault free) computers just accepted the changes and continued tp work  . . .
    Mine, after the Windows and the Norton update begins to accepts Vaio Updates !
    Interestionly it did 3 Vaio software updates first and then, after a restart, it did an update to the updater !
    I now have Vaio Update  Ver 5.5.3.10280 . . . . . . Time will tell  if it "sticks".
    I hope this helps someone ~ for sure, it mystifies me!
    I will continue to "watch" this thread.
    • Válasz
    Feb 2, 2011
    Létrehozás ideje Mar 13, 2012 7:24 PM
    Since I reported above, the machine was OK  for a while and then continued with its old "odd" behaviour.
    After a very long and often circular search which was not made at all simple by the web site returning to the USA version of the site . . . . . I eventually found:
    SOAVUD-00260791-1070.EXE
    Which is the latest version of
    VAIO® Update Software Update
    which I duly installed and since then . . . .All is well.
    Here is a link to a "grid" which shows if it is "The one for you" !
    http://esupport.sony.com/BR/perl/swu-matrix.pl?upd_id=7224
    I actually found it through the "My Sony"  / Support / software and drivers . . .I have not provided a link to "My Sony" because as you will soon find out, the menu is driven in the first instance by COUNTRY and then Model Number (Good luck with that ~ It did not recognise mine because the site kept opening a lik in the USA version!!)
    My advice would be:
    1.  Check the grid and make a very good note of the file name and version
    2.  Download the file from whichever model is closest to the one that you have.
    • Válasz
  • 1 bejegyzés a következő időpont óta:
    Mar 17, 2012
    Létrehozás ideje Mar 17, 2012 12:13 PM
    I've been wrestling with this for months with none of the solutions working.
    I have now accidentally got it working though I can't guarantee this will work for anyone else.
    I had a bluetooth peripheral device, a Samsung mobile phone, reporting a missing driver in device manager.  After searching for a solution, I downloaded and installed Windows mobile device center (the 64bit Vista version which posts said would work with Windows 7).  This fixed the bluetooth driver AND hey presto VAIO update was working again.  Good luck.
    Colin
    • Válasz
  • 5 bejegyzés a következő időpont óta:
    Mar 14, 2011
    Létrehozás ideje May 2, 2012 7:01 PM
    Rich912
    I am having the same problem. I have a VAIO VPCEE2S1E/BQ 64bit windows 7. As you can see below,  my VAIO update IS version 5.5.1.09220 :
    Vaio update has been working fine since I have had this laptop. Then today I went to check for updates, and this update box appeared:
    Now, when I click on "yes" nothing happens. So, I cannot update. Any idea how this can be fixed?
    Any help would be gratefully appreciated.
    Regards,
    Daniel.
    • Válasz
    Aug 28, 2004
    Létrehozás ideje May 2, 2012 7:37 PM
    Hi Daniel,
    As you will be aware this old chestnut has been plaguing us for months and Support insist that the problem has been solved – like hell it has!
    All I can suggest, assuming you have not already done so, is that you update to version 6.4.2.11150 of Vaio Care.
    http://www.sony.co.uk/support/en/product/VPCEE2S1E_BQ/updates
    Rich
    • Válasz
    Mar 14, 2011
    Létrehozás ideje May 15, 2012 1:13 PM
    I have managed to resolve this problem i had - see above posts - by following the link that RICH912 posted, i.e., http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?m=VGN-AW41MF_H&l=en_GB
    clicked on the latest downloads for my OS, i.e., WINDOWS 7
    and then downloaded the update :
    VAIO Update - 5.5.2.11060       32 / 64 bits   24.3 Mb   25/11/2011
    from the list of updates provided.
    Everything is now working fine.
    Message was edited by: danegee
    • Válasz
  • luhanna 2 bejegyzés a következő időpont óta:
    Dec 8, 2012
    Létrehozás ideje Dec 8, 2012 8:25 PM
    hi, same problem,my updater wont work but i can install most of them manually, which is a pain and very time consuming, i need help from you guys also.
    MAYBE SONY SHOULD ASK MICROSOFT FOR HELP WITH UPDATING PROGRAMES.
    • Válasz
    Aug 28, 2004
    Létrehozás ideje Dec 9, 2012 10:18 PM
    Hi luhanna,
    What is your Vaio product number and what version of Vaio Update do you have installed?
    What exactly is the problem you are experiencing? Is it that your model is not recognised or that the Vaio Update requires an update that will not install?
    The more detail you can provide the greater the chance that someone will be able to assist.
    Rich
    • Válasz
  • Titan2501 1 bejegyzés a következő időpont óta:
    Dec 28, 2012
    Létrehozás ideje Dec 28, 2012 12:48 PM
    Hi Rich!
    I have just bought a Touch Screen Vaio with Win8 64 Bit.
    Product n ame: SVT1312V1ES
    Vaio Update version nr: 6.0.0.08170
    If I click the update, then the same issue arises as for many people in this thread:
    "A new version of VAIO update is available..."
    After I click the update, it says: "Cannot lunch VAIO Update, because it is being updated to a newer version".
    It say "Downloading..." on the icon, when I hover the mouse over it, but after that, nothing happens. If I click it again, the whole process starts over again.
    Any ideas, advice on how to fix this would be grately appreciated.
    Thanks, and Happy Holidays from Hungary : )
    Best regards,
    Zoltan
    • Válasz
    Aug 28, 2004
    Létrehozás ideje Dec 28, 2012 1:16 PM
    Hi Zoltan,
    As your model was released with Windows 8 I don’t think the problem is related to the issues raised in this thread.
    There is one Vaio Care manual update available on the Support site that you could try but I have no idea whether this will resolve the issue.
    http://www.sony.co.uk/support/en/product/SVT1312V1ES/updates
    If this makes no difference then all I can suggest is disabling your internet security and try the automated update again. Otherwise you will need to raise a case with Support.
    Rich
    • Válasz
  • _anders 4 bejegyzés a következő időpont óta:
    Oct 28, 2012
    Létrehozás ideje Dec 28, 2012 8:24 PM
    I have the same problem as you, only my Vaio Z is upgraded from Win 7 to Win 8.
    • Válasz
  • Fillitsa 1 bejegyzés a következő időpont óta:
    Dec 28, 2012
    Létrehozás ideje Dec 28, 2012 8:29 PM
    I have the same problem, Windows 7 bios R1190V3
    • Válasz
  • iadiape 1 bejegyzés a következő időpont óta:
    Dec 29, 2012
    Létrehozás ideje Dec 29, 2012 12:56 PM
    I have the same problem, again [as I remember this issue occurring priovusly].
    Model:  VPCCW2Z1E
    OS:                    Win 7
    Vaio Update: 5.6.1.02150
    BIOS Ver:            R0170Y7
    Although this is a little weird since the lastest version on Sony product website for this model is:
    Thanks,
    • Válasz
Ossza meg
